Hey CB7Tuners
Ive been lurking in the shadows for awhile gettin tech info from you guys, but I figured its as good a time as any to make an account for this post.
At speeds above around 40mph my 91 manual cb7 is making a humming noise. this noise varies with the speed of the car, not with engine speed. It also gets worse on sweeping right turns.
All of this seems to point towards a bad front drives side wheel bearing. However, I jacked up the car today and there was absolutely zero play on the drivers side wheel (or any of the wheels for that matter).
Furthermore, I jacked the drivers side up, and put it in 5th gear with the engine on to try to get the noise to come on, but I didnt hear anything over the crapload of gear noise coming from my poor differential.
It’s worth mentioning that I think the noise is coming from the front left but my girlfriend sitting in the passenger seat thought that it’s coming from the right side of the car.
Also, I noticed that front tires had inner wear.
Is there any further tests I can do to diagnose the problem? Does it sound like a wheel bearing (even with no play in the bearing) or do you think its something worse like a tranny bearing?
Thanks
Thanks
