Hey guys! As some of you already know, I'm spending money left and right to make this build fast and reliable. Here are just some of the Parts that I've accumulated over the past month or so.
Parts List:
-CX racing Civic half size Alum. 3 core radiator
-Flexalite Single 1250 cfm fan with shroud meant for the civic radiator
-Innovative 95A rear mount, and 85A side engine mounts
-Competiton CLutch Lightened Forged steel 14lb FLywheel
-Action Clutch 2ms 6 puck ceramic kit. (500hp capable)
-T304 Dsm stainless steel o2 housing with external wastegate flanges
-Tial F46 (46mm) Wastegate (One expensive are wastegate!)
-Dsm stainless turbo outlet Jpipe for FMIC kit intstall
- AEM 320lph pump, e85 version (good for around 600hp with the stock size steel lines)
-Evo 3 style stainless steel gaskets from extreme psi
-TD05H 20g Hybrid turbo with billet extended tip wheel, 9 blade turbine, and 7cm hotside.
-Omni 3 bar map sensor good for like 29 psi IIRC
-Hondata s300 v3 p28 ecu with boost by gear and e85 compatibility
-Fuel Lab 6 Micron fuel filter with fiberglass element (e85 compatible)
-6AN fuel line kit adapter with fittings and hoses
-AEM AFPR with 1:1 boost rise ratio
-AEM billet high flow fuel rail
-Five o Motorsports 1400cc High impedance Injectors (e85 compatible)
Can you tell I'm going e85?? lol...
-AEM wideband Uego
-Turbo oil feedline and drain kit from FastTurbo(dot)com
I've got tons more i can list but i''ll do that another time when the build is done and ill have all a master parts list for those intrigued.
Goals are 415-450 wheel hp
and of course, the engine has been fully built
Parts List:
-AEM wideband Uego
