Out of the fire and into the frying pan...
So I recently got my car started after over a year and a half sitting. I had an unknown issue that caused a small burn in the motherboard of my P72 and after replacing that with a P28 started popping the under dash ECU fuse. I went through two of them before number three managed to not pop ( same amp rating ).
That problem not occurring again (I'm not gonna say I solved it) the fuel pump would prime and the car would start and idle had an issue with a solid CEL, surging idle and connectivity issues between my S300 and Smanager. I managed to take car of that by re-seating the S300 on the pins. So at that point the car would prime the fuel pump, start/idle properly and there was no CEL.
I had taken it for a couple of slow rolls up my street before figuring out the ECU issue (no faster than 20/25 mph) and it would rev just fine. Now with everything else corrected or otherwise not showing any obvious symptoms the car will not rev above 1900 rpms, not at idle or while moving and I have no speedometer function on the dash ( datalogs show the speed and it seems accurate ). Now my friend/tuner seems to think that because of sitting so long the fuel filter and injectors got gummed up (which I'm planning on addressing). I'm just so frustrated at this point that I think an outside opinion or diagnosis would probably shine some light on the subject.
