My AC has 134a fittings and a small leak that i found. What i am having issues with though is getting the compressor to engage using the ac button. I jumped the ac compressor to battery and it does work and starts to pump cold air. I then jumped power to the relay and it engaged from there too. When i try to jump power to the number 7 fuse nothing happens. At this point I was lost. If power goes from the ac button to the number 7 fuse and to the relay why is nothing happening from here? I also tested for power at this fuse. Still nothing. When i test for power at the relay I get nothing aswell. I tested the relay and close the circut. It reads 0 resistance on prongs 3 and 4 when i jump power to prongs 1 and 2. the relay is fine but it isnt getting power from the number 7 fuse location. Am I missing something else here? Also I cannot locate my ac diode under the left kick panel on the drivers side. just hard to find anything up there after the alarm system was installed. If you have any info on what I should be testing for from fuse to relay or in-between please educated me. Thank you for reading.
Also I think We need a dedicated section to just ac. This is a basic but complicated system since a simple mistake can cause it to not function. Ill post pictures of what i have done and tested tomorrow before work.
