90-91 Accord Gas Leak Problem!
    Hi guys ,
    So I have been having a gas leak smell problem that has been going on for almost a year now. Every time I would fill up it would smell strong of the fumes and even after passing the halfway point in the gas tank I can still smell the fumes. I have already replaced the tank from before and found that the top of the gas tank was cracked. But now with the new gas tank I would not expect to happen. I have already checked the fuel line and have not seen any leaks (but if anything I will go back over again if anything to double check).
    So anyone have any tips or tricks , or ideas on how to deal with this?
    Thank you guys!
    Honda Accord 91 ~ F22A1 ~ Mindy ~
    If you're sure the tank and lines are good, and you're not leaking fuel on the ground, I'd take a look at the filler neck.
      might look at the gasket on the top of the tank also
