I have a 1992 honda accord ex coupe. Who has the best affordable struts for front and rear?
Best affordable struts
http://www.cb7tuner.com/vbb/showthread.php?t=139318
Depends on what you want. Best is Koni Yellows with your choice of spring. Cheapest? Go on RockAuto and see what's there.
CBs have shocks, not struts.
Anyway, as said, "best" depends on what you plan to do. If you're using stock springs and simply want stock replacement, any quality brand will do. KYB GR2, Tokico HP, and Koni STR.T are good choices for stock replacement (and as said, even good for a VERY mild drop... no lower than 1.5")
I've never heard of Detroit Axle, but I'd be pretty comfortable in saying that they're just generic junk. By looking at their website, it seems to be what they sell. The do axles and steering racks in-house. Everything else is most certainly ordered from an undisclosed overseas supplier... I wouldn't trust that for such important parts.
KYB GR2s will give you the best ride I think for the most economical price.
There are others cheaper out on the market, but they won't last long (monroe, gabriel). Those are carried at the parts stores and their seals aren't nearly as well made as the Japanese KYBs are.
I have a set of KYB AGX (performance, adjustable damping) shocks that have been on my car since August 2005 and they're still functioning decently with no signs of leakage. That's pretty good considering since I'm lowered about 2.5" on some stiffer Ground Control coilovers. I can tell they're tired though, and will probably get replaced after my 5 lug conversion is completed.
Originally posted by deevergote View PostDecent? No. You're not going to find anything quality like that. Such things exist solely to profit off of people's laziness.
Originally posted by zedjr10 View PostI have a 1992 honda accord ex coupe. Who has the best affordable struts for front and rear?
While I always maintained my cars using only OEM parts I couldn't afford to have a mechanic replace my shocks at that time either.
You don't state if you plan to have a mechanic do this or if you're doing it yourself?
If you're looking to save money because someone else is doing it the solution is to DIY it which is exactly what I did. You can have good quality shocks and cut your expenses in half.
I inexpensively purchased a set of spring compressors from Harbor Freight (about $10 I recall) and armed with my Helm manual and several user group forums I spent several days tackling it. It may not take you as long but I gave myself extra time just in case. You can also rent or borrow these from several auto parts stores.
If you take it slow, use the spring compressors carefully and practice common sense it's not hard. It's actually more intimidating and time consuming than difficult especially if it's your first time.
By bypassing the mechanic and finding the best online dealer pricing I bought 4 Honda OEM shocks and saved about half the cost of having a mechanic do it...
FWIW here are a few pics to get you started:
Front replacement:
The rears were simpler:
Except here where I encountered an alignment issue while installing the lower bolt:
If I recall the fix was to jack the each side (not on the fork but near the disc to raise the suspension up slightly) until it realigns and then insert the bolts otherwise no issues:
Hope this helps...Last edited by hiptech; 06-20-2018, 11:17 AM.
Originally posted by deevergote View PostThen why bother asking, if you already decided to buy crap?
Good luck.
