As the title states its a 93 but the key wont come out, i have two keys for it one is in the ignition and i cant get it out, i have no idea, could it possibly be because the used to be an auto and is now a manual?
93 se key wont come out of ignition
Did the key work before? Just to be sure, the wheel isn't cranked to one side so the that the steering lock is binding it up? The automatics do have an interlock so the key can't be removed unless the transmission is in park (and maybe neutral).90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostDid the key work before? Just to be sure, the wheel isn't cranked to one side so the that the steering lock is binding it up? The automatics do have an interlock so the key can't be removed unless the transmission is in park (and maybe neutral).
Yeah, it used to come out then one day it just wouldnt
Graphite is a bad idea, use white lithium spray, the graphite will clump up inside the lock cylinder all around the springs and tumblers and impede movement of them. Also if you have lots of keys and junk on your key rings swinging from your ignition as you are driving down the road, then you are causing damage to your lock cylinder, the tumblers are brass and wear easily against the key. Get a carabiner and key all of your key sets seperate.Last edited by Size9zombie; 02-04-2017, 12:37 PM.
The fact that you said it use to be an auto makes me think that the switch that makes the car think it's in neutral may have gone out and it may think it's in drive which I don't think the car will let you take the key out. But I'm not very familiar with automatics.~Nick~
Originally posted by Size9zombie View PostWhat shape are your keys in?
The shift interlock is a cable driven type lock from the gnition to the shifter assembly, if the car was converted to a manual them the interlock cable was most likely removed from the ignition, femoved the 2 piece plastic shrould around the steering column, 3 phillips head screws underneath, and look to see if there is a cable running into the bottom of the ignition switch
http://www.cb7tuner.com/vbb/showpost...&postcount=104
On the conversion for the CB's the GRN/WHT + BLK sets it to park, so I was wondering if that was still connected properly.
Originally posted by Size9zombie View PostThe shift interlock is a cable driven type lock from the gnition to the shifter assembly, if the car was converted to a manual them the interlock cable was most likely removed from the ignition, femoved the 2 piece plastic shrould around the steering column, 3 phillips head screws underneath, and look to see if there is a cable running into the bottom of the ignition switch
Originally posted by Granite CB7 View Post^Did you check my link? Is the car still in PARK?
