Hello everyone I'm new and not from around so my english may be little bad...
So I decided to tune my F20 engine, and put an h23 intake/exhaust 4-2-1 to the engine,new air intake, down pipes and so on, but after the swap my car does idle poorly on cold, I checked the fast idle valve, it was ok I change it yesterday just in case, and nothing changed. I put an plate on the air boost valve, same old song... and I'm running out of ideas how to make this intake work does someone know how to fix this problem?
By the way, when cold the fast idle thermo valve does not suck air, when I remove the cover plate then I push with finger air rushes in the valve and the RPM goes high, I try to loosen the cap of the valve to reduse presure from the spring in it but still nothing. I Have an idea that the FITV and the air boost valve work together somehow,and this problem is with both tuned p28 ECU and the factory one so I'm gesing this is mechanical ussue. But as I say I'm running out of ideas how to make this work.
Best regards
Best regards
