Brought my 90 Accord into the garage to change the thermostat and see if the water pump/thermostat are working (Been Overheating, replaced a leaking coolant line and I still overheat)...
After removing the thermostat but putting everything else back, for some reason I can't get it to turn over. I think something else unrelated just happened to go out at the same time..
I put the brand new plugs/wires from my 92 accord on it in order to test the plugs. No spark.
I haven't gotten as far as checking the fuel or compression, because I believe I have already diagnosed no spark. If I have my test light grounded, and the engine cranks... but putting the lead of my test light onto the ignition coil spring produces no light/spark, that at least means bad ignition coil correct?
There was a little bit of oil in the rotor cap, but after clearing it and replacing the ignition coil I can't imagine why it wouldn't work again. Any advice or thread links are appreciated!
