cb7 h22 cranck no start
    Hi.
    I am having troubles with my cb7 with h22 swap. Car runs fine over 2 years. Today I was trying to start it, But it just keeps cranking. After several attempts the car started with huge cloud of white smoke. It idles very rough and after few minutes the smoke stopped. Took it for a ride and it runs horrible!! it creates very loud sound while accelerating (like gunshots ). Now the car is difficult to start and if it starts it idles crap when you take your foot of the pedal it will shut off. Any ideas!
    Engine: H22 stock 5 speed
    ECU: P13 / tried my buddies p28 chipped same
    Recent part replaced:
    walbro fuel pump
    fuel filter
    spark plugs
    battery
    radiator
    White smoke is burning coolant. Sounds like your head gasket called it quits.
      Where exactly is the white smoke coming from? Under the hood, out the exhaust? My H23a1 smoked out the intake before, because a coolant temp plug broke, go figure .
      If at first you don't suceed, then skydiving is not for you.
      I try not to down talk anyone, when I read my old questions I realize I was an idiot too.
        It came from the flex pipe and exhaust
          Then I would agree with Deeve on the head gasket being a likely suspect. Check you coolant to see if it is low, and check your oil to see if it has coolant in it. Last time you drove it did you happen to notice if it was trying to overheat or anything?
          And also another guess would be maybe an O2 sensor going bad and the car just dumping fuel in it??? That one might be far fetched though.
            I don't think it would be the O2 because I tried my buddies p28 chipped with O2 disabled. The car never overheated on me but i'll check the coolant today
