Tips on replacing the speed sensor?
    Hi cb7tuner users. I've been having a little bit of trouble replacing the VSS on my 90 accord. I removed the air filter parts to gain more access to it, but I'm stuck on removing one of the bolts on it. I can get my socket around the first bolt closer to the motor itself. The bolt closer to the tranny is being covered by some kind of shifter cables and housing. Do I have to remove these in order to gain access to the second VSS bolt? If anyone has done this before on a manual tranny please let me know how!!
    Thanks!!!
    You just have to pull the cotter pin on the shift arm and the clip off the linkage to move them. Real quick and easy.
    '93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
      It's just two 10mm bolts if I remember right. Get a wobble extension to make it easier.
