When i turn, it sounds like something connected to my wheels are squealing
    Could be the rack, or just the tie rods. Honestly, if it's all torn up, replacing all of it might be a good idea. The rack is discontinued, I believe. Might be able to find refurbished or aftermarket, but definitely no more new from Honda.
    I've never had to replace a steering rack, but I've heard it can be a pain in the ass. Certainly doable (everything on these cars can be done with patience and the right tools), but it's not the most fun. Give yourself plenty of time to wrestle with it.
      I've replaced the rack before.
      It's a pretty straight forward process.
      Rack and Pinion DIY
      *when installing the new rack, make sure it is set as if the car is turning right. It's the easiest way to get it back in the car. Put the passenger end in first, then get the driver side in.
      Make sure you are good at doing bench-presses or you have a helper. The rack is heavy and awkward. You will be holding it up and pushing it into place.
      GL
        What brands for aftermarket would you consider better quality? I want to find something online but i dont want to get any of those cheap kinds.
        Thanks in advance.
          Rack and Pinion DIY
          GL
          Thanks!
            The other option is to rebuild the rack yourself: http://www.cb7tuner.com/vbb/showthread.php?t=207857
            The seals are still available from Honda; also available aftermarket.
