Turn Signal conundrum
    Hey guys, me again. '91 DX Auto 4-DR. Today my issue is in the turn signals. At first if I barely moved the signal arm up to change lanes, I'd have to kind of jiggle the arm the other way to get the light on the dash to stop blinking, because it would be very dim and rapid. Now as soon as I turn the ignition on, the dash indicator starts flashing quickly and dim. The turn signal relay clicks like crazy. The right and left signals both still work as far as that's concerned. However, With the left signal on, the right front bumper mounted signal still flashes, very dimly. The rear right signal only comes on when you actually push the arm up to make a right hand turn, and goes off as soon as the wheel is returned to center.
    Is this a relay problem or a switch problem? It's my understanding that on 90-95 Accords, you don't have to remove the wheel to replace the turn signal switch, so it wouldn't be difficult. I am just trying to gauge what my issue is before I start throwing parts at it.
    Thanks
    I don't jerry-rig, i make custom parts with alternative materials.
    '91 DX 4 door Auto
    You should try changing the flasher first, easy and cheap.
      Turn your hazards on, if they work change the switch.
        I clicked the hazard on and it works, although i thought that the hazards and turn signals used different relays. anyone know if there's a DIY posted on here for replacing the switch?
        '91 DX 4 door Auto
          Remove the screws from below that hold the column cover on. Remove the cover. Turn the wheel to access the two (if I remember correctly) screws that attach the switch to the column. Disconnect electrical connector. Installation is reverse.
          DIY for possibly fixing the switch: http://www.cb7tuner.com/vbb/showthread.php?t=196539
