Got a 92 accord Ex. AC blows hot air.. But I'm not sure why. The compressor clutch engages the belt and the freon seems legit at 70F. Haven't looked into it more than that but maybe a thermostat or something of the sort?
air conditioning
What do you mean "Freon seems legit at 70 F"? How are you measuring it? Have you converted to R-134a?
You really need a manifold gauge set that measures pressure on the low and high side so you can monitor the whole system.1992 EX, 306,000 miles - Track toy - M2S4, H23A1, ST rear swaybar, Wagon brakes, GC coil sleeves, KYB AGX dampers, Stoptech pads, Toyo Proxes R1R, 2.25" exhaust
Stock F22A6
VIR, 5/22/2016: https://youtu.be/eR5-ylSPsxk
H23A1 powered
NCCAR, 9/4/2016: https://www.youtube.com/watch?v=TI5WpxGrEpE
CMP, 10/16/2016: https://youtu.be/DOqoe5f-GLY
Originally posted by masospaghetti View PostWhat do you mean "Freon seems legit at 70 F"? How are you measuring it? Have you converted to R-134a?
You really need a manifold gauge set that measures pressure on the low and high side so you can monitor the whole system.________________________________________
1985 Rx7 GSL- SOLD
2003 Altima - SOLD
1991 H22 Lx - SOLD
1991 Lsv Da9 - Project Boost
1992 Virgin Ex - Daily + All black Gutz an things..
IF you have black interior panel pieces for sale please PM me!
Your AC and cooling systems are separate. Thermostats have zero to do with AC.
http://m.harborfreight.com/a-c-manif....google.com%2F
Get a kitchen thermometer too, and put it in your vent. Should be in the 40s not the 70sLast edited by F22Chris; 03-28-2016, 09:01 PM.
I truly know nothing about freon or Ac's. Im assuming that R134A is an alternative but Ill look into it. What I meant by the freon being legit is that when i tried adding some a few years ago I was told by an admittedly questionable source that 70 degrees was the sweet spot for accurately measuring it and adding it to a system. The guy told me to check the low end and the high end of the system, however mentioned nothing about a manifold gauge.. So anyways, Ill grab a manifold gauge to check both ends and then I'll post my findings. Also, not sure if its relevant but the temperature dial in the cab does turn past the point that should be the hottest and highest point, and no matter where it is on the scale from coolest to hottest it makes no noticeable difference in the air coming from the vents, with the AC button engaged or not. Just a side note in-case thats relevant at all.
R134A is what replaced R12 as the refrigerant used in automobiles. The R12 that was originally in your system is no longer legal, and no longer available for sale. It is necessary to convert the R12 system to be compatible with R134A.
It is very likely that your system has a leak, and that there is no more refrigerant in there.
R12 on eBay
The US just banned the import of r12. You can still buy cans that haven't sold yet but are still in the US.
Also, if you live close to Mexico, well guess what? They will recharge r12 all day long down there.
