weird idle after installing PnP throttle body
    Yeah I'm with raf, if just changing the tb causes all your issues then I think you know what the problem is.
    sold! But here's my build thread for those interested.
    http://www.cb7tuner.com/vbb/showthread.php?t=206864
      Not sure why no-one mentioned this but did you check your TPS sensor as per the manual instructions? A false reading here pretty much explains all.
      Update:
      Checked tps and it's a bad tps. Stuck at like 3.2 volts. Thanks Raf99. This most likely solves the problem. Changing out tps with known good one from doner as this Tb rebuild was off a wrecking yard cb7 before I got second cb7. Will install Tb again after tps replaced and adjusted and let everyone know if it's fixed
