92 Accord LX IAC problem? Vibration when throttle opened?
    So i bought my accord for $900. Ive added full ebay exhaust, ngk wires and plugs, new battery, and an aem short ram intake so far. the problem is that im hearing this annoying buzzing sound coming from the iacv. if i turn the key to II with the iacv plugged in it buzzes and if i unplug it it stops. i tried replacing the iacv but when i put the new one on it did the same thing. what could be causing this? Also, while driving, once i have the throttle opened up and the car is at about 2200 rpm there is a loud buzzing noise like something is vibrating. any ideas?
    Did it do this before all the cheap ebay was put on ?
    Car safety checks
    Fluid Capacities
      yes it still made the sound but now that i have the aem intake on her the noise is a lot louder. i hear the sound coming ouit of the end of the sri more so than from the area where the iacv is. as for the buzzing when my rpms are at about 2200 no this is a new thing but i had the entire tb, plenum and manifold off and put new gaskets on everything because i was getting oil into my spark plug wells
        the buzzing when the rpms rise almost sounds like air is passing by something making it vibrate because it will stop if im really pushing her like going up a hill or something. ive read before that apparently something in the tb could vibrate because of more airflow through it. is this true?
