distributor help
    distributor help
    hi guys i just swapped my f20b into my 91 lx. i need some help as i am converting from the external coil to internal in my h22 distributor. i know how to hook the positive for the coil up but i cant exactly figure out how to hook up the ground. do i do it the same as the positive and cut the wire coming from the plug as i did on the positive? or do i plug it in to where the negative came in and plugged in on the external coil distributor. sorry if i'm not very clear i dont know how else to explain it. i have searched relentlessly and i cant find any pictures or detailed descriptions. any help would be greatly appreciated. i'll try post pictures to show what i'm talking about. thanks in advance.
    The easiest way to convert it from external to internal coil is to use a fuse in the external coil plug and just plug in the internal coil like normal. There a few different write ups on this on these forums.
    Here is one write up on any motor swap for this issue.
    Swap Facts for the CB7
    MRT: 1993 Honda Accord SE Coupe (Lola)
      thanks alot, i appreciate it. I decided against that and just decided to go with external coil being as my distributor is external coil. i just picked up a coil to use. figured it would be easier. because the harness for my car is set up for internal coil but it would be easier to convert that. i think
