Touche. I shouldn't make sweeping generalizations
h22 header on f22
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
off topic for a sec.
Originally posted by deevergote View PostNo.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
He's not directing you to any particular thread. That's his signature (everything below that white line.) He's not trying to help you... just bitching about you not knowing the answer to your question.
Accord problems, would you like me to dig up some of your old posts from when you were new? I know it was 4 years ago, but I can very clearly recall some questions you posted that could've been answered by a simple search. For example, "Is the 94 accord obd same as 91 accord" (a thread that received one answer, which was thorough and correct, and that member didn't complain about your lack of searching as he answered your question.)
Please show others the same courtesy you were shown when you were new. If you are going to complain, at least do so with some sort of helpful contribution.
Originally posted by deevergote View PostHe's not directing you to any particular thread. That's his signature (everything below that white line.) He's not trying to help you... just bitching about you not knowing the answer to your question.
Please show others the same courtesy you were shown when you were new. If you are going to complain, at least do so with some sort of helpful contribution.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
