does anybody know were to get a phenolic spacer to go between the intake and the head on a f22a6 . apperntly a h23 one would work too.
f22a6 phenolic spacer
I heard of thermal gasket for intake manifold to head, its thicker then regular IM gasket and keep the IM cooler. Idk if you have done this yet http://www.blacktrax.net/images/products/BT_IMS_350.jpg and there is a diy on this forum. Which is way cheaper. I just did this to my car yesterday also putting a h22 upper plenum at the same time. Well if the thermal gasket is what you are looking for bisimoto.com carry them.
I was going to say try Hondata. But just went to their website and it seems they don't offer the f22/h23 gasket anymore.
TIP: Remember to re torque the intake manifold nuts after driving the car a little bit. After a few heat cycles the gasket will soften a little and settle it self a little thinner than the first time your torqued it down. You may even notice when you go back to torque them down again, a few of nuts may only be hand tight.
