clutch question
    clutch question
    I am about to replace the clutch in my 91 lx. I saw on here that exedy seems to be the way to go. I have found one on rock auto for a good price. However, I am leaving for Texas in about a week and with shipping it would make my timeline very short. I called my local advance auto and they have a perfection clutch in stock for roughly the same price. Does anyone know if they are as good as exedy? It's made by zoom. I don't want to have to replace after 30xxx miles. Would I be better off just ordering the exedy and just have to put it in last minute? Thanks in advance
    Just get exedy or valeo.
      Exedy is your best bet. OEM quality is the way to go (and Exedy/Daikin is the OEM manufacturer)
      However, if you're really in a pinch, the Perfection clutch would probably be just fine for normal use. If you're not racing, or pushing more than stock power, it'll probably hold up a good long while.
      I would STRONGLY recommend buying an OEM throwout bearing directly from Honda, however. Especially if you get the Perfection, you'll want a quality bearing. Cheapie aftermarket bearings can fail, and when that happens, the clutch is usually toast (I learned that lesson the hard way!)
      If you're not replacing your flywheel, you're going to need to get the stock one resurfaced. Replacing is a better option, though.
      Also, be prepared to replace an axle or two, as well as any ball joints or bushings that you damage or discover to be damaged in the process. It's not uncommon to damage an axle or lower ball joint when doing a clutch job.
        Valeo is an OEM for many companies. As Deev said, be prepared for axle replacement. Get output shaft seals for both sides, and some synchromesh.
          I just meant OEM Honda. Valeo is good, and I'd trust them... but if Exedy/Daikin is an option, that's the way I'd go. Especially since the throwout bearing that comes with those kits is usually decent (though apparently not the same as the part you get from a Honda parts counter...) I can't vouch for Valeo's bearing.
            Thanks guys... I'm probably going to hold out until I can get the exedy... I just went and picked up an f20b last night... Got it for a deal... Balance shafts removed... Manual tensioner... And it's the manual version so since I'll be swapping soon I'm gonna hold out until the last possible minute so I can make sure it's done right
