Hi guys, I know that there are very minor benefits to running an a6 ECU in an auto car such as higher shift points, but are there any to be had if this was put in a 5 speed car? Thanks!
F22a6 ECU in f22a1 5 speed?
The ECU has nothing to do with the shift points. And no, the PT6 (F22A6 ECU) will offer no benefit for the F22A1. In fact, you would probably lose power. The PT6 is tuned for a different camshaft profile, and an intake manifold with an IAB system. The only time you would ever want a PT6 on an F22A1 is if you swap in the F22A6 camshaft and intake manifold.
dev's right . i did this in a pinch to get me till pay day . the car had a lot less power . i would not recommend this as it can do damage and give you really bad gas mile .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
