starting dificulties
    At the last driver change at our last race our car wouldn't start. It would just barely turn over, but not enough to start. So we push started it and finished the race.
    We thought it might be a bad battery. We did by this one on the cheap at the pick and pull. We put a charger on it and much later I tried and just barely got it to start. I let it idle for a long time, but later it wouldn't start. So I got the jumpers on it and it still wouldn't start, it still was acting like a bad battery, but I know it was getting plenty of juice from my other car's battery / alternator. The battery actually had good voltage. The alternator puts out almost 14v when running. When attempting to start it, the solenoid does engage and it just barely turns over.
    I believe that it is the starter motor. I'm about to buy a new one from rockauto. I'm just looking for a second opinion.
    1991 Accord Lemons Race Car, "The Minnow" RIP
    1993 Accord Lemons Race Car, "SpaceEx Starship"
    Neuspeed Race Springs, Koni Sports, Acura CL Rear Sway Bar,
    Adj Upper Control Arms -3.0deg front, -2.0 deg rear
    M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel. A4 Header, 2" exhaust all the way back, catalyst delete, delta 262 grind, glasspack muffler, PT6 ECU.
    Acura CL3.0 Brakes Front and Rear, Raybestos St43 Pads, Redline 600 Brake Fluid
    Jump the solenoid to batt positive and the starter should turn normally. If it does, your problem is somewhere else. You still could have a bad ground so make sure that the ground below the starter is good as well.
    YouTube Clicky!!
      I have seen a starter go bad with these symptoms once in person, but it apparently happens often caused by internal corrosion. It sounded exactly like a bad battery. So check voltage at batt with car off, check at starter with car off, then push start the car and check again. If that all reads correctly it's the starter.
      ......father in law has it back again. Time to shine
