I was installing my 4040 proportioning valve, and stripped the fitting that goes into the valve, attached to the line towards the left rear. I then stupidly cut it off, and tried to use a double flaring tool, but I didn't have enough room to use the tool. Is there a way to remove the brake line from the proportioning valve to the left rear of the car? There's a plastic cover that holds it to the underside of the car that I can't break loose.
Metal brake line
You could just cut a little further back and use a flaring tool there, then make up the difference in space with a double-ended soft line.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
I might give that a shot, but if anyone knows how to remove these clips, I'd rather just pull a junkyard line.
http://i300.photobucket.com/albums/n...psswpeuj2w.jpg
