93 accord crank no start. Injectors not spitting fuel
    93 honda accord 243k miles. Ive been down for a few weeks now and have narrowed down(atleast i think) my problem with my crank no start condition to my fuel injectors not working. Fuel pump primes, main relay fine. Im getting spark and ive went over my timing meticulously. Could it be my cps? Does the main relay control injector pulse as well? Please help i dread the thought of taking it to a shop.
    If you're getting fuel to the rail, but the injectors aren't working, it's likely your injector resistor box. They don't fail frequently. A junkyard replacement should work fine.
      Is there any way to test the box?
        I'm sure there is, but I don't know offhand how it would be done.
          I'm having this exact same issue, have you figured it out yet?
            this is a old thread man . best bet is start you're own asking qestion's and stating you're issue along with make / model / year.
            Car safety checks
            Fluid Capacities
