i was wondering if the acura cl3.0 hub assembly and brakes would fit on my wagon. after searching around i found an interchange page on here that said the cl would but wasnt sure if the 3.0 would work because the cl axles would be from the 6cly and not the 4cyl. has anyone on here ran the 3.0 hubs and brakes on the cb9/cb7 suspension with stock axles from the f22a6? i want to run the rotor over hub set up. any help would be appreciated.
hub assembly and brakes off cl3.0
Yes, they will fit perfectly fine onto the axles. Do you plan to just buy the hubs themselves, or have you found the whole knuckle at the junkyard?My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by Jarrett View PostYes, they will fit perfectly fine onto the axles. Do you plan to just buy the hubs themselves, or have you found the whole knuckle at the junkyard?
If that's the case, use the entire 3.0CL knuckle. While you're scavenging parts, grab the front and rear sway bars and brackets from the CL, as well.
And this may be more work than it's worth, but if you a 5-lug swap is ever in your future for this car, you want the rear knuckles, too. The Prelude hubs used to do the 5-lug swap won't fit on the wagon rear spindle.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
thanks jarrett. that helps me out alot. i have seen threads about upgrading the sway bar and the benefits but now thats a go. sometimes it hard to know if someone knows or is guessing but i am checking your build on the coupe and have no doubts in my mind! lol that car is clean. a motor swap will be in my future. now im only showing 104,xxx on the dash. she runs pretty decent. what about the shock/springs that i have for the cl? should i sell or will they bolt up?
Sorry, I meant to post about those, too. To answer your question, yes, they will fit. However, you should concern yourself with quality here. Without knowing what brands you purchased for the CL, it's impossible to know how well they're made and whether they're worth putting on the Accord.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by oni_cb7 View Postthe 3.0cl knuckles will increase the amount of negative camber on the front wheels.
