Intermittent wipers
    Intermittent wipers
    hello has anyone had the intermittent wipers stop working? It still works on the other 2 speeds. I wasn't sure if there was a relay or a module that controlled these. combination switch has been replaced My car is a 91 lx sedan autotragic
    There is an electronic control box located in the interior fuse box. Try replacing that.
    YouTube Clicky!!
      Is that the icm? could that be the reason the turn signal portion of my corner lights don't work. They don't come on by themselves but if you have the lights on and pull out the bulb and put it back in they stay lit until you turn the lights off or try to use the turn signals/hazards, then they go dead. Never seen anything like it. Also replaced hazard switch, relay, turn signal/light switch, sockets, bulbs. Haven't seen any CB7ers with this Particular problem or for that matter on any car ever
        Yes the ICM.
        That is weird. I don't think the ICM controls that, but I won't discount it. Judging by the things you replaced, you could have faulty wiring somewhere.
        YouTube Clicky!!
          I do believe that when this happened to me, the fuse controlling the lighter socket etc was out. Only intermittent was out, other speeds worked. I would check your fuse box first.
            Yea its had me scratching my head for a while now. Been like that for over a year now since I bought the car. When I got it every single ground was loose, climate control and radio stayed on 24/7, power locks didn't work, antenna didn't work. The door chime would have a spaz attack and play me a little song randomly while driving. Basically nothing but the engine worked. I have since fixed all the electronics exept the wipers and those corner signals. The passenger seat belt has a mind of its own. It likes to wait until people are half way seated and then try to take them out. Its funny to watch. Driver side motor is dead but I just unclip it. Ill get around to replacing it eventually. I'm gonna go to the junkyard tomorrow and get an icm or 5 and see if that fixes anything. I've been over pretty much the entire harness and see no problems. As a tech of 9+ years Ive never seen any lights like this. Either they work or they Don't, but of course wierd old Honda problems don't have to make sense. Anyone that says cars don't have a soul hasn't owned a Honda from the 90's
              The new ICM fixed both the wipers and the turn signals. Thanks for the help! I guess it makes sense, something has to make them flash the opposite from the other ones. The chime also works now!
                Nevermind about the alternating part. I see that they flash with the others. I didn't snow because mine never Worked before. Again thanks for the help
                  Glad you got it fixed, I was unaware that there was a ICM that controls them. I learn more about these cars everyday.
