How to remove tranny?
    Remove the knuckles with the axles attached and take them to a shop to have the nuts taken off.
      The hardest part of removing a tranny is figuring out where to grab it. If you grab from the rear you might turn it on and if you grab it from the front you might get a little poke.
      Oh wait, wrong tranny...
        When I first had to remove my axle nuts I took a metal fence post about 4-5 ft in length had a buddy in the car holding the brakes, let some air out of the tire to get better traction and used a jackstand to support the wrench. I soaked the crap out of it with PB blaster and was able to get one off. The other one I had to drive it up to Goodyear and ask them to use their impact gun to break it. They had to use their 3/4 drive impact gun.
        But simply removing the whole assembly and bringing it in would be just as good if you feel unsafe driving with the axle nut loose.
        ~Nick~
          Gross. Your name is totallys brutals though.
          Try putting the breaker bar on the ground, socket still on the nut while in reverse. Break shit or break shit trying.
