Intake and valve cover help?
    I recently bought a 93 accord. I looked and it had an aftermarket intake along with a weird filter on top of the valve cover. I looked at the throttle body and i noticed there was a plug. Is my setup correct with the hose going from the intake to the valve cover? And the hose disconnected from the throttle body with a nipple, And just a filter on the valve cover? I lurked on these forums for a while and I noticed some people have difference setups such as the breather switched to the other port by the intake. I'm really confused and any help would be greatly appreciated. ps: I also noticed that the filter/breather is soaked in oil and I was wondering if that was normal.
    Thanks,
    Skeazzy
    Those are both part of the PCV system. I don't know about that filter but is the car running badly or not at all? If it's not giving you any problems then I wouldn't worry about it. "If it ain't broke..."
      It idles weird and i just don't want to break anything
        That port is supposed to connect to the port on the intake manifold that is currently capped. Run a hose there and replace your PCV valve while you're at it.
          For some reason a whole bunch of people think that using that air filter (breather) in place of the PCV system works better, because you dont get oil in the intake. But unless the motors built, A standard setup or a catch can setup works much better than a breather. i bet its dirty and super oily? theyre always like that.
          Now, the intake to valve cover hose is correct, so thats fine. Run a hose from your PCV valve to the capped spot on your intake, as jarrett said.
          Those breathers are for looks and dont work. if you care that much about Oil in the intake, use an oil catch can.
          Ebay ones are fine but put steel wool in the bottom.
          sold! But here's my build thread for those interested.
          http://www.cb7tuner.com/vbb/showthread.php?t=206864
            X2 on the catch can with steel wool. Honestly, unless you're making excessive crank case pressure (turbo or built) you should just go back to stock.
            the air coming from the engine has tiny oil bits that clog the valve and dirty the intake over time, which is why people use catch cans.
