main relay troubleshoot solved
    finally figured out what was wrong with my tcu. after changing and testing everthing on my 90 lx automatic and checking all the codes from the tcu I figured it was the last code I had got which was 14. at least I updated a few parts on my car and the problem was the main relay switch under the driver side dash. Did not know that the main relay is out when the car does not start up even when the engine turns. anyways this site had helped out a lot.
    Do you still need help with the code 14? couldnt quite understand what you're saying.
    sold! But here's my build thread for those interested.
    http://www.cb7tuner.com/vbb/showthread.php?t=206864
