Any body got and good recs im ready to order it but want to go with a good source
Who should i order my H22 through
Speaking of JDM H22's when do you think that Japan will run out of them? Seems like they got a million of them and it amazes me they haven't run out completely already seeing that ppl have been swapping them since the mid 90's.“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
Many of the less reputable sites likely sell them from other countries, such as Australia (higher mileage.) Sure, they'll run out eventually... but they'll be available to those that look. If you can still buy original engines from cars made in the 20s and 30s, you'll be able to find good Honda engines for the rest of our lives.
Originally posted by deevergote View PostMany of the less reputable sites likely sell them from other countries, such as Australia (higher mileage.) Sure, they'll run out eventually... but they'll be available to those that look. If you can still buy original engines from cars made in the 20s and 30s, you'll be able to find good Honda engines for the rest of our lives.
The F22A9 I got from tigerjapanese for instance. From Australia.
Originally posted by F22Chris View PostJust do a full inspection when you get it. Compression, bearings, etc..
Gasket kits, belts, seals, tune-up, VTEC solenoid gaskets, water pump/timing and stuff. I think most people do this anyway for piece of mind. I would.
Of course, I had pros install mine, and I'm still fixing their halfassed installation.
I believe Steve states that you must replace certain seals in order to keep is warranty valid. But I would not go to anyone else but hmo. I've seen 3 motors come from him and all 3 still going strong.~Nick~
