I picked up a 92 ex with an h22a1 swap in it, they had the fan wired to the headlights so it turned on the lights on. I believe I corrected the wiring but once the fan kick on it stays on the entire time engine is running. I'm thinking it could be the sensor getting stuck but looking at the haynes manual wiring diagrams it says they go through a " fan timer unit " has anyone ever had this problem before?
cooling fan staying on, does't cycle
I would read through this thread, it should be able to get you pointed in the right direction. It does sound like a problem with the fan timer switch though.
http://www.cb7tuner.com/vbb/showthread.php?t=171056
