93 Accord lx EGR
    93 Accord lx EGR
    Using my Haynes manual and other reading this is what I have done. When pulling 10hg vacuum at EGR Valve car does NOT stall. EGR does NOT leak down. What does this tell me? Thanks
    why'd you do that? more background info would be sweet
      Idle/Surge between 1500-2000 rpm. Found info online/book thats says check EGR.
        PM sent.
          Update: Pulled plugs from intake and cleaned ports then run seafoam through intake using vacuum line off brake booster. Still rough idle b/t 1500-2000. Engine now stalls when pulling vacuum on EGR. I am going to try to check IAC etc per manual resistance check. Just wanted to follow up in hopes this helps someone one day.
            Check IAC.....Good. Cel came on and was code 7 so replaced TPS then short test drive seems like that soved orginal idle problems. Now new problem is it will not shift out of PARK checked all fuses and they are good. Brake lights work so that switch seems good. No idea how replacing TPS could cause this. Any sugestions?
              The shifter not working is probably coincidence. I can't think of any reason replacing the TPS would cause that issue. If your brake switch is still working, it's probably the shift lock actuator in the shifter assy. In the mean time, you should be able to stick a key into the slot by the shifter (shift lock release) to be able to shift out of park.
              If your idle issue comes back, my normal checklist for Honda's is: check coolant level, check for vacuum leaks, adjust/clean FITV, clean IACV, set ignition timing and set base idle.
                UPDATE: TPS did cause it not to shift out of park. When tps was install closed throttle signal out put was around 1vdc( slotted holes in tps would not allow for further adjustment). I opened up holes in tps and got it to around .65 vdc. Car seems to run better with idle issue gone so after a few maintance things I plan to make it my daily driver again. Hope this thread will help someone down the road.
