h22a1 - h22a4 oil pan
    Just bought a 92 ex sedan with an h22a1 swap and the oil pan is crushed. I have am extra H22A4 aluminium oil Pam along with the pickup, can I get away with using the pan for the a4 or do o need to purchase a new oil pan?
    An H22A4 aluminum pan will work just fine, and you don't need an oil pan rubber gasket since the block and pan will heat expand equally when they are the same material. Honda themselves just uses liquid gasket (Hondabond for example) on aluminum pans.
    Euro CB7 2.2i [F22A3] --> [H22A7]
      You can use the aluminum pan. Just get a tube of Hondabond and the small rubber gasket that goes on the transmission end. Also, the pick ups are the same between H22s.
        Thanks guys, where can I get the little rubber gasket on the transmission side?
          At the dealer. The part number is:
          11251-P5K-000
            Nvm found it on estore.Honda.com Thanks for all your input, helped a lot.
              Thanks
