NO beeping sound ignition
    Check continuity
    You should check your ignition switch under the dash. If you have a Haynes manual or watch the previous video for a 1997 Accord. I found the plug in portion of the switch behind the lower left fuse box. It is brown with a solid white wire, a solid yellow, a yellow/black and a black/yellow. If you have a multimeter with a continuity test feature, you can evaluate whether the switch is good or not. Don't throw parts at the problem until you eliminate the possibilities.
      I literally almost gave an actual response to this.. Start a new thread bud.
