Hello there, I have a very big problem with my cb7 1991 Honda Accord Sedan, basically when I put the key on the ignition, there's no beeping nose, I turn the whole key over and nothing happens, my seat belts don't move, no dash lights, windows won't go down, no crank either no nothing, I don't know what it is, I did checked the fuses. PLEASE HELP!
NO beeping sound ignition
This may sound dumb, especially since you checked the fuses already, but are your battery terminals corroded, or is one of the terminals not connected well, or at all? Does your radio work in the first key position?
MRT
14.38 @ 98.66mph
The quest for 9s ceased, now the goal is a circuit track monster!
Current fastest Laguna Seca Lap: 1:52.346
I had the same thing two days ago after charging my battery, the car has been parked all winter.
Turns out that after cleaning the battery terminals everything was fine and dandy.Bought from: Night Wolf, bassrock234, sonikaccord, 904drACCORDMANG
92 Accord, F23a franken-engine, N/A forever.
Which fuse box did you check? There's one under the dash and one under the hood. The fuse box under the hood is the one you actually want to check. However, this sounds like a dead battery. What do your battery terminals look like? If they're covered in white then that's likely your problem.
Originally posted by af_1132 View PostThis may sound dumb, especially since you checked the fuses already, but are your battery terminals corroded, or is one of the terminals not connected well, or at all? Does your radio work in the first key position?
Ok, so I'd almost rule out the battery or the battery fuse then. But before I do, your battery could just need a good charge. Do you have a voltmeter to test the battery voltage? If the battery reads healthy, then it sounds like an ignition-specific related problem, such a bad starter or main relay or any number of ignition related things. A couple questions:
1. Can you hear the fuel pump prime in ACC position?
2. Does the car beep when the key is just in the ignition or first position when the driver door is open?
3. In ACC position, do the instrument cluster indicators light up?Last edited by af_1132; 02-25-2015, 08:52 PM.
MRT
14.38 @ 98.66mph
Originally posted by af_1132 View PostThis may sound dumb, especially since you checked the fuses already, but are your battery terminals corroded, or is one of the terminals not connected well, or at all? Does your radio work in the first key position?Originally posted by af_1132 View PostOk, so I'd almost rule out the battery or the battery fuse then. But before I do, your battery could just need a good charge. Do you have a voltmeter to test the battery voltage? If the battery reads healthy, then it sounds like an ignition-specific related problem, such a bad starter or main relay or any number of ignition related things. A couple questions:
2. Car does not beep when the key is in at all.
3. No response from from the instrument clusters, or the indicators light up
I'll check the battery to see
