Whats up people? Does anyone have info on h22 cams from an auto transmission? I was running them on my 5spd. Replies will help as I just got my remachined and rebuilt long block built and now im thinking, I mean really thinking on rebuilding my head. Its stamped p13 on the head. But has auto cams.
Need help with my cams
There is no difference between automatic transmission and manual transmission H22s in regards to the camshafts. The differences lie in the gearing of the transmissions themselves (while very slight) and for the 5th Generation Prelude the addition of the Active Torque Transfer System, which is incompatible with our chassis without some serious modification to the frame. I believe you have the H22 confused with the F20B, which does share those differences.
Also, a "long block" would be an assembled block and cylinder head. If the head is not included it would be a "short block".'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
