swap?
    swap?
    Will a h22a4 with h23 head work? Seen one for sale for $600
    Sticky: Read this before asking about doing a Frankenstein build!
    http://www.cb7tuner.com/vbb/showthread.php?t=187140
    Sticky: Common Swaps Info can be found in here. PLEASE READ HERE FIRST
    http://www.cb7tuner.com/vbb/showthread.php?t=159041
    FYI - Using a non descriptive title "Swap?", can get your post deleted.
      Yes. Long as it is the H23A vtec head
        Sure it could work.
        It would work with the H23 Non VTEC head as well...... It would basically be an 87mm bore F22B.
        MR Thread
        GhostAccord 2.4L Blog
        by Chappy, on Flickr
          Mixing and matching engine parts can cause problems, especially if done by someone that has little to no experience assembling engines. If you're buying it put together like that, I'd suggest putting it out of your mind.
          Sounds like this is the leftovers from an H23A block with H22A head.
          Also, if that block is from a Prelude SH, you'll have issues mounting the intermediate shaft properly.
          And yes, had your fellow knowledgeable cb7tuners not already replied with useful information, this thread would have been deleted due to the vague title. In the future, please be sure your title describes your question. This site is intended to be a searchable database. It doesn't work so well when the thread titles are too vague to be of any use.
