All that needs to be replaced is the rubber line and bypass the dampner. It is a little cylinder looking thing on the passenger shock tower. Air tends to get trapped there and is a pain to bleed.
Clutch Reservoir Issues (Lost Hydraulic Compression)
Originally posted by djcaz_aom View PostAll that needs to be replaced is the rubber line and bypass the dampner. It is a little cylinder looking thing on the passenger shock tower. Air tends to get trapped there and is a pain to bleed.
Originally posted by DGOfTheCentury View PostYea thats what i am talking about, but i need one for a car, the only ones i could find were for bikes. What i meant by standalone is separate, majority of clutch reservoirs are attached to the master cylinder. CB7 has a standalone.
Originally posted by JFISHTHECREATOR View Postthey are about the same size in capacity, and i have seen a fet fellow cb7t members use those instead of buying a factory oem.
I will give some closure when i find time to install everything again, give it a go
In my experience, the clutch line took quite a long time to work out all the air. This was after changing out a leaky slave and master.
The reservoir is not sealed air tight as other people have mentioned.
If your doing it alone, pick up a pressure bleeder, I'm pretty sure your problem is bleeding related.
