Originally posted by GhostAccord
View Post
F22b1 Forged Piston Decision
Originally posted by wagon-r View PostFor the not so knowledgable (I just learned about this myself a few months ago), forged pistons expand more as they get hot than cast pistons. This makes the piston-to-cylinder wall clearance much more important with forged pistons that with cast pistons. In fact, what I read before is that you should get the forged pistons first, then send the pistons to the machine shop with the block so that they can bore the cylinders to exactly match the piston size.
Thank you for bringing that up..... also a note, there are a couple different alloys in use with aftermarket forged pistons. Some expand less than others... depending on the composition.... Not all forged pistons are the same, 2618 vs. 4032 are comon forged Aluminum Alloy pistons!
I do realize that you need to have the cylinder bores sized to your pistons.... but it's always nice to have your block checked first before you buy a particular size piston...specially if that size is stock.... that's all I am saying.
Here is a hypothetical..... What happens if you buy 85mm forged pistons and you find out from the machine shop that your stock 85mm bores need to be bored out to 85.25mm, 85.5mm or 86mm? Even .25mm is a hell of a lot for a forged piston to make up in it's coefficient of thermal expansion. My Forged Wiseco pistons require only a 0.0762mm piston to wall clearance. If that isn't as much as you need to remove, you now have to take the pistons back and buy something over sized......Last edited by GhostAccord; 12-31-2014, 10:56 PM.
Low silcon pistons vs. high silicon pistons.
DGOfTheCentury, check out the book "Honda/Acura Engine Performance" by Mike Kojima. It's old, lots of the info is fairly outdated, and it focuses mainly on B and D series engines... but there's still a TON of useful info in there, including a good deal of technical information regarding forged internals and turbocharging. It's where I got my start, and I have yet to meet anyone who read through that book that made a fool of themselves on a forum Even if you have a decent understanding of how engines work, there's bound to be a few new bits of information you don't know in there. I strongly recommend picking up a copy.
Originally posted by deevergote View PostLow silcon pistons vs. high silicon pistons.
I recently bought this 91 accord and i managed the f22b1 swap on a POA, because the f22a was junk so i have a great confidence in my potential, i just need to learn numbers and yield of particular modifications.
CB7s are my first favorite Honda, EG hatch being the second, have yet to own one though (people here sale them like they have gold chassis)
Originally posted by GhostAccord View PostHere are a couple other books that will take you more towards tuning and electronics/sensors side of things.
Engine Management: Advanced Tuning by Greg Banish
Performance Fuel Injection Systems by Matt Cramer & Jerry Hoffmann
