Hi there...going to try to make this quick since I'm new. I have a F22b1 block with a 85mm bore...I found forged pistons for the engine. However I have two choices I am torn between, when it comes to engine reliability. Two different bore sized pistons, one is the standard 85mm, the other being 85.5mm both at the same compression. Now currently I am only trying to build a tough NA engine. Although in the future I want to run 15lbs boost. Would .5mm over...give me a stronger ringland? Or should I just get the standard size at 85mm. I have heard weak ring lands for Hondas recently so I just want to be able to do it right.
F22b1 Forged Piston Decision
If you are going with forged piston ring lands are not the issue. What bore you choose may depend on the condition of your cylinder bore. If they require any sort of rework you will not use stock 85mm.
Are these forged or cast pistons that you are looking at? Most of the cheaper ebay pistons are of the weaker cast varieties.
If you're looking to build a respectable N/A car now with considerations for boost in the future, look into Bisimoto's piston and rod kit. It uses H22A rods and 29mm compression-height DSM pistons to improve the rod-stroke ratio and bump compression to 9.3:1. While that is not much of an improvement for an N/A build, it is a slight boost over stock with plenty of room for boost later on.
Tuning has come a long way these days and many tuners are able to tune even high-compression engines for respectable turbo applications. It all comes down to what your budget is, who you plan to have tune it (as well as their chosen software), and what the application for this build will be. The main point is that if you're considering turbocharging the car in the future, regardless of your desired power level, upgrade to forged pistons now.
Also, the pressure alone is not a telling figure. 15 psi on a 14B is a lot different than 15 psi on a PT6266.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by GhostAccord View PostIf you are going with forged piston ring lands are not the issue. What bore you choose may depend on the condition of your cylinder bore. If they require any sort of rework you will not use stock 85mm.
85mm bore 9.0:1-
https://www.raceeng.com/p-31047-wise...t-526p85r.aspx
85.5mm bore: 9.0:1-
https://www.raceeng.com/p-31046-wise...-526p855r.aspx
Sorry it took so long, I thought I would get an email notification of some sort.
Originally posted by Jarrett View PostIf you're looking to build a respectable N/A car now with considerations for boost in the future, look into Bisimoto's piston and rod kit. It uses H22A rods and 29mm compression-height DSM pistons to improve the rod-stroke ratio and bump compression to 9.3:1. While that is not much of an improvement for an N/A build, it is a slight boost over stock with plenty of room for boost later on.
As far as I am concerned the stock motor can run 5-10lb boost no problem...but I know me, I would beat the shit out of it
So tht is the only reason I am considering forged internals.
Because quite literally I was just going to rebuild motor and slap a turbo on it in my first mind.
Mismatched parts? Dimensions are just numbers. If a GM LS3 has valve springs that are the same dimensions as an F22A (they're not) then who cares what they were for? But that's not the point. I'm telling you that Bisimoto sells what you're looking for in a package. They're going to tell you that it's "custom", but the parts are just borrowed from the applications I gave you before.
Also, 9.3:1 is perfectly safe for a turbo application. If you have a number that you feel like you have to be under for detonation's sake, then it sounds like you're reading too many Super Street magazines from 2003.
And what is 5-10 psi without knowing the size of compressor we're talking about? A bicycle and an 18-wheeler can both have tires inflated to 50 psi. However, you know that the 18-wheeler has a much higher volume of air in the tire. That's a static example whereas a turbocharger is fluid, but the concept is the same.
I will also disagree with your confidence in the F22A/B's ability to withstand boost as easily as you think. Let's assume your "5 psi" mark is 225whp. Your ringlands on the factory pistons will fail. Whether or not it happens soon after you install the turbocharger or not is anyone's guess. However, it will fail. This is the importance of forged pistons.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Keep in mind also that all F series engines have open deck blocks. This isn't an issue until you get to higher boost, or very high RPM N/A builds... but there comes a point where the block design becomes a weakness in itself. If your future turbo plans include making over 400whp (which, quite honestly, is overkill on a lightweight FWD car, IMO...) then you'd be wise to look into resleeving the block when you build it. Better to do it now and get it out of the way, than to have to rebuild the whole thing again later on.
As for compression ratio and turbo... the necessity for a low compression ratio is pretty oldschool. These days, tuning options (even budget options, such as Crome) offer a good deal of control, allowing you to run a considerably higher compression ratio than was possible 15 years ago (which is when many of our "rules of thumb" originated.) Not that 9.0:1 is all that low (still higher than stock), or that 9.3:1 is all that high (as Jarrett said, still totally safe for boost...) These days, a competent tuner could boost an engine that's 11.1:1 or higher. Lower compression just gives a greater threshold for error.
Be careful... when you start telling the people you're asking for advice what can and can't be done (the stock engine should NEVER be boosted, unless you're cool with blowing it up...) If the knowledgeable people on this site get the feeling that you're going to ignore them, they won't waste their time offering their guidance.
Originally posted by deevergote View PostKeep in mind also that all F series engines have open deck blocks. This isn't an issue until you get to higher boost, or very high RPM N/A builds... but there comes a point where the block design becomes a weakness in itself. If your future turbo plans include making over 400whp (which, quite honestly, is overkill on a lightweight FWD car, IMO...) then you'd be wise to look into resleeving the block when you build it. Better to do it now and get it out of the way, than to have to rebuild the whole thing again later on.
Could the wiseco 85mm 9.0:1 be a go? BTW I purchased the sleeve kit with the rebuild kit...the brace shaped like the cylinder walls tht goes in between the cylinders and the block right? Also when i said mismatch parts i did nlt mean it was bad, i just do not feel assured tht things will fit correctly. The last thing i want to do is be returning something i bought from the internet. Some day I hope to get over tht.
As for the compression ratio there is a wiseco 85mm 11.1:1 compression piston, but I am not prepared for such an upgrade (as far as i am concerned tht would require p28 chipped, new cams, injectors, preferred crank forged, and some other stuff i forget). As for the f22b1 potential i just heard about tht from another forum, thts why I said "as far as I am concerned" meaning I could be wrong...once again Thx for the assistance
I could actually use a little bit of schooling on psi to turbine size applications, because I bought everything for the forced induction except the turbo...I have no idea which one to buy, they only seem to be listed by A/R which I looked up and tht led me virtually nowhere.
So far I am enjoying the forum...this is the first forum I actually considered being a member of
Originally posted by Jarrett View PostMismatched parts? Dimensions are just numbers. If a GM LS3 has valve springs that are the same dimensions as an F22A (they're not) then who cares what they were for? But that's not the point. I'm telling you that Bisimoto sells what you're looking for in a package. They're going to tell you that it's "custom", but the parts are just borrowed from the applications I gave you before.
I had my cylinders bored in my F20B block at American Engine and Grinding in downtown Houston. They took longer than I'd had preferred, but did top notch work. Their prices are $40 per cylinder and they matched the bores to the specs I gave them when I took my pistons in.
Always give the machine shop the pistons before having them do the work.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Now there is a catch to buying pistons before checking out the cylinders. If you are looking to buy stock sized pistons and the cylinders do end up requiring even just a little bit of work... Now you may not be able to get the piston to wall clearance that you wanted.
I realize that we are talking fractions of an inch. But that's all it takes to have a skirt or ring land wear sooner due to rocking/piston slap, every fraction counts in the end. As much of a PITA that it may be. It is better to check the bore before you buy the pistons. Specially if you are looking at staying stock bore.Last edited by GhostAccord; 12-31-2014, 11:04 AM.
Very true. My recommendation was for the 86mm pistons that require an overbore either way, but a good policy to live by, nonetheless.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Ok so I will have the machine shop take a look at the block...I'm sending both the head and the block in for inspection and parts cleaning then I will go from there with the pistons...got my new tool set in today as well craftsmen's 309pc
One last question before I attempt to bring this topic to a close...I saw on bisimotos website, a 3 layer steel head gasket...I was considering getting tht one instead of the flimsy one tht came with my rebuild kit....would tht be a good idea? Con's pros? Using ARP head studs if tht makes any difference.
BTW I do not live in Texas I'm just from there...I actually live in Florida...I did not know it would do tht...edit timeLast edited by DGOfTheCentury; 12-31-2014, 05:52 PM.
