Main relay pinout scheme
    Anyone come across this before? I have a 92 DX that someone has obviously been underneath (car's got squirt!), but it's sudden refusal to start after running fine and then getting really wet inside, suggests the main relay.
    So I pull it and search here, find this pic linked, but in order to test, the pinout assignments on the tech page don't match the numbers on the relay itself.
    I went ahead and ran the test exactly as it's shown on the page below, 2nd picture, with 0 response audio or electrical, but until I know for sure I had the pins right I can't say for sure the relay is bad.
    Hope again that makes sense, lemme know if I can clarify. BTW first post here (duh) but this looks like a great resource; we just scored this car but it's not gonna fly for work purposes, but I bet it'll be a great SCCA autox ride
    The indicated assignments on the relay itself are sequential, like:
    86b2
    7531
    vs. (see it shows basically two different layouts, not sure why?)
    edit: I meant to add the relay is an RZ-0088. thx
    I realize that's a little convoluted up there, in short what I see on the relay as far as pin assignments, isn't what they're showing up there. I did the test like shown above the best I could, but not sure if it's enough to really rule out the relay.
    Maybe I'm just over thinking it.
    I'm pretty close to just swapping it out, but money is beyond tight atm. Guess I gotta do what I gotta do.
    If anyone in the east SF bay knows where I can get a known-good relay for a 92 F22a accord, I'd be obliged..
      Welcome to Cb7tuner
      Man if you were in houston, tx i have 3 good relays you could have haha
      I'm having the opposite problem my injectors wont squirt....
