are the marker light turn signals tied into a different fuse? the ones in my bumper work fine. but both sides in the marker lights dont work. ive changed bulbs and sockets. and cut the wires back and wired in a new socket and still dont have anything. got tired of messing with it for the day. ill be looking at fuses tomorrow maybe. everything but my cigarette lighter and dome light work. are they all tied together?
i dont believe the marker lights should blink. just the ones in the bumper.
unless you mean your marker lights do not illuminate at all
in that instance you need to do some electrical diagnosis. see which is missing from the circuit, power or ground. look at wiring diagrams, to find which fuse is in control of that circuit, etc. do your parking lights work otherwise? i.e, in the rear?
yea, all my other lights on the outside work. i find it odd that there are bulbs that dont light up with the parking lights or blink with the turn signals. theres gotta be a reason there are bulbs there...
its the ones that would be in the orange area. the ones in the clear area work fine. i think they blink on my dads car.
Their names are "corner lights" and "bumper lights" to keep the confusion down.
The corner lights are supposed to illuminate and blink via two 194/168 type bulbs per side.
The bumper lights are turn signals only.
I made a brief video to demonstrate a properly working set of turn signals.
*Note my corner lights a LED's and I also have DEPO amber corner and bumper lenses so they may look different that yours. They may even flash in a different sync that mine.
Originally posted by H311RA151N View PostTheir names are "corner lights" and "bumper lights" to keep the confusion down.
Haha, I was just wondering which pod was which when i go to put the front end back together and pop in the leds.. thanks. Im glad you know what youre talking about AND can provide visual references
well now that we have a technical term for them. why dont the corner lights blink? i would imagine that they would be tied to the bumper lights. but they work. i have bulbs out of the bumper lights right now but that shouldnt have anything to do with them. when i had the bulb in the drivers side bumper light the corner light didnt work.
The corner lights are controlled by the icu located on the interior fuse box.Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
Originally posted by lucifer1 View PostThe corner lights are controlled by the icu located on the interior fuse box.
the corner lights are tied in with the dome light. dome light fuse is out in the engine compartment. also the windshield washer bottle motor is ran through that fuse as well.
i do need an icu though as that controls intermediate wipers, rear defrost, and i believe the cigarette lighter. from what ive read those things not working is due to the icu. and mine works when it wants to. anywhere to buy one of those new?
Originally posted by Hemi440 View Postfalse, also where is the interior fuse box? passenger or drivers side?
Indisputable fact is the icu controls whether the corner signal lights blink in sync with other turn signals when lights are off or out of sync in when lights are on.
Fuse 22 underhood power dome light, part of icu, cig lighter, door lights, trunk light, and power ant.
Fuse 1 under dash powers the part of the icu that controls the corner light blinkersManual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
can you site somewhere that lists whats on each fuse? if not im just going to disregaurd your information. what i did invalidates fuse 1. unless the underdash box is wired to fuse 22. your information may be for a different year.Last edited by Hemi440; 12-02-2014, 09:44 PM.
