d4 light blinks
    d4 light blinks
    Hi I have a 93 accord and my d4 light on my cluster has started blinking... I read up and saw shift solenoid might be the problem but I changed it with a new one and still gets d4 light .. Can it be anything else ?
    Keep reading and searching and you will find how to check the codes and eventually find out it is actually your TCU that burned out. The longer you drive it in this condition the more damage you will do. Your car is in limp mode most likely and it will be wearing on only 2nd and 3rd gear's clutch packs.
    Other symptoms might include but are not limited to:
    Shifter not wanting to shift from park position
    Slow acceleration from a stop
    High RPMs at 70mph
    Feels like it only has two gears
    Kicks in and out of overdrive
    there are a few more symptoms, search for "TCU codes" on the forum, if you can't get it to return a code then most likely the TCU is bad.
      Thanks for the reply . I changed both lock up solenoid and shift solenoid because I read that it could be those but I also had a feeling it was the tcu.. It flashes after 50 mph
        I was troubleshooting a high idle when warm today. I'm not sure why at the moment, but simply disconnecting the Engine Coolant Temperature (ECT) sensor caused my D4 light to flash on a 92 EX coupe automatic.
          When you get a tcu , get em from the junkyard and grab 3 of them , they burn out a lot. If you pull em from a yard they're only a few bucks.
            Pull the code, fix the problem, reset the computer. Stop guessing.
              ^ what fleetw00d said.
                The flashing D4 is indicative of a TCU error code. Until you pull the code, you don't know which of the 2 dozen things it could be indicating is causing the problem.
                  For the price of 3 junk tcu you could just buy a refurbished unit with updated electronic components that won't burn out. OP still hasn't pulled codes. You give out some odd advice emosun.
                    If i wanted to find out what code it throws out what do i need to have in order to initiate that test? I have the car manual with codes i believe. I just dont kno how to jump it in order to find what code it throws
                      Look at the top of this section. You will find the answer you need in the thread marked "READ HERE FIRST".
