F22a1 2.2L can i put a .48mm turbo on it stock everything, I need help because I'm basically getting the turbo for free and I wanna put it on my 91 if i run low psi do ya'll think it would be okay..?
Turbo question
that looks like it would be perfect my buddy had one of those on his saab and i put it on his 93 with an a1 that had 200k and it was fun at 6psi and one day he called and said to come over and watch this and his gauge said 13psi and then boom lol but ya i think if you good it all good the right way i think a good 4-6 psi will be good for 50k dont beat on it tho take care of it. good luck keep us posted.
Originally posted by cb7dd View Postthat looks like it would be perfect my buddy had one of those on his saab and i put it on his 93 with an a1 that had 200k and it was fun at 6psi and one day he called and said to come over and watch this and his gauge said 13psi and then boom lol but ya i think if you good it all good the right way i think a good 4-6 psi will be good for 50k dont beat on it tho take care of it. good luck keep us posted.
You've already stated what you've experienced personally, so why would you encourage someone to intentionally compromise their engine? This may be the OP's only form of transportation. For him he may not have the chance to "have a little fun". One boost spike and he's possibly walking.'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
The key words in your statement are "awhile". "Awhile" means for an unspecified time but surely will end at some point. We don't endorse that here. We preach tried and true, reliable setups. "Awhile" could be 6 months, "awhile" could also be 6 hours.'94 JDM H22A: 178whp 146wtq
Originally posted by cb7dd View Posti was saying that he can run this set up at low psi but if he boosts above 8 or so it will begin to fry. i understand it may be his dd but if he doesnt beat on it he will be good for a while but if he shows it off and acts tough and pushes the turbo then he is toast.
He could run it at low psi and last for 50k miles.
Honestly, 5 psi from that small of a turbo wouldn't be worth the hassle, imo. You still have to get piping, tuning, injectors, intercooler, various maintenance items. It's going to be at least 1k. Tuning is going to be the expensive part. Then why have a turbo setup up if you have to be gentle with it? I want something I can romp on and not have to worry about things breaking. That alone increases the driving experience.
On stock internals, it's just a matter of time before the ring lands give out. As said, it could be a while... it could be tomorrow. This is a 20+ year old engine we're talking about. I've seen brand new pistons directly from Honda blow in 6 months after being boosted. The guy that built it was experienced in building turbo engines, and he worked as a Honda tech. He was no noob. The turbo was properly sized, the tune was good, he didn't beat on it... and those brand new pistons lasted 6 months.
How long do you think your 24 year old pistons are going to last?
It is also important to understand turbo sizing. A turbo that is too small will generate a LOT of heat. Not to mention the fact that you'll be in boost while driving at normal RPMs, adding additional strain. Your best bet is to use a turbo that doesn't really start to spool until 3000rpm or so. It will do less damage to your engine, and it will save a ton of fuel.
Originally posted by sonikaccord View PostYes, you should do it. Make sure you post a build log for us to follow, too!
Judging by the apparent inlet and output port sizes, that turbo at least looks to be on the small side for a 2.2 litre engine. As a rough comparison the turbo on our Saab (that blows about 6psi) looks significantly larger than that one, and the Saab engine is only 100cc larger than the Accord engine.
If it is actually as small as it appears in the photo, at least it would be unlikely to be have much lag, though an overly small turbo might become a restriction at higher rpm. It's conceivable that a restrictive turbo would improve bottom end / mid range power, but strangle the engine at higher rpm, so there might be less high rpm power than stock?Regards from Oz,
John.
