I have a full megan racing exhuast on my f22a4. The header/downpipe gasket keeps burning/blowing out. it gets loud , and sometimes when i rev it , it will backfire. does anybody else have this problem?
backfires?
Did you reset the ecu? How long have you been driving it with the new exhaust?
EDIT: Is the ECU stock?Last edited by sonikaccord; 10-30-2014, 09:19 PM.
Poor quality gasket? Perhaps the flange surfaces of the header and / or the downpipe are not flat enough? If so then parts of the gasket may not be in good enough contact with the flanges, and as result get too hot and burn out.
The backfiring is caused by negative pressure waves inside the exhaust causing atmospheric air to be 'sucked' into the exhaust through the leaking gasket. This causes an excess of O2 inside the exhaust, which causes unburnt fuel to burn ('explode') inside the pipe.
Excess O2 won't get into the exhaust only on the 'over-run', but since there are always positive and negative pressure fluctuations within the exhaust, it will affect exhaust gas O2 content most of the time (i.e. increase it). This will affect O2 sensor output, and the ECU will 'think' that the engine is running lean, so the ECU will inappropriately enrich the AFR...Regards from Oz,
John.
Originally posted by johnl View PostPoor quality gasket? Perhaps the flange surfaces of the header and / or the downpipe are not flat enough? If so then parts of the gasket may not be in good enough contact with the flanges, and as result get too hot and burn out.
Originally posted by JFISHTHECREATOR View PostI used the gaskets megan racing sent me, i cleaned the surfaces on each pipe.
After fitting the gasket and running everything up to temperature, let it cool down and retighten the nuts. Check nut tightness again after a few days normal running.
Originally posted by JFISHTHECREATOR View PostShould i try the permatex copper gasket stuff and spray it on the gasket?Regards from Oz,
John.
i put a new gasket on it, tightened it , warmed the car to operating temp , jacked it up , then re tightened. its fine right now - been a week. if and when it goes out again i will spray some permatex copper spray a gasket onto the gasket. if that dont work i have one more after it , so i would use it. then either buy more gaskets , or go back to my stock A4 headers. although i did see a significant change in power with these megan headers/pipes.
Originally posted by JFISHTHECREATOR View Posti put a new gasket on it, tightened it , warmed the car to operating temp , jacked it up , then re tightened. its fine right now - been a week. if and when it goes out again i will spray some permatex copper spray a gasket onto the gasket. if that dont work i have one more after it , so i would use it. then either buy more gaskets , or go back to my stock A4 headers. although i did see a significant change in power with these megan headers/pipes.For the love of god, STOP putting H.I.D's in stock housings!!! Projectors ONLY!!!
Originally posted by 802cb7 View Posthow significant? can you also double up the gaskets if needed?
Doubled up gaskets may possibly result in the gaskets running hotter because the faces of the gaskets in contact with each other are further from the flange faces (and insulated by the non metallic layers of the gaskets). The gaskets will lose heat into the metal of the header and the downpipe (which are always radiating substantial heat away in use), so the further parts of the gasket are from the flange metal the less heat they may lose...?Regards from Oz,
John.
as for the power increase , i cant tell you hp, because this thing has never hit a dyno. but the acceleration from 0-60 , and 60-100 was quicker.
