When I turn left I develop a shake Please help
    Alright like the post says when I take a left my cb7 starts to shake. I changed the cv axle and the strut. When I changed the cv axle the shake was a lot less but its still there. I haven't changed the control arm yet which also needs to be changed. One more thing when i slow down from 30-25 mph my steering wheel begins to shake i don't think my rotor is warped and i have new brakes all around. Any help is much appreciated.
    Check your strut/radius rods.
    YouTube Clicky!!
      I changed the strut its brand new.
        sonikaccord means the part below in the video and not the struts that the springs ride on. The part is actually called strut/radius rods.
          Where do you feel it coming from? Front or rear? How do you feel the shake? Do you feel it through the steering wheel or brake pedal or the body? Have you modified your suspension? Have you been in an accident recently?
          We need more data.
            We need more data.
            I feel it through the steering wheel. Idk I'm taking my rotor off I think it might be slightly warped
              If you're not braking during the turn and your pads aren't severely dragging on the rotor, a slightly warped rotor shouldn't cause the car to shake. Check that all your wheels are straight and make sure your tires don't have a broken belt - look for a bulge in the sidewall or tread, or tread that wanders back and forth as the wheel is rotated.
