This all has started after i got a used new f22a4 engine, lighten flywheel and new clucth. When after all of that my car ran great for about a week but but for the last couple weeks the problems are getting worse. When I start my car (cold mostly..) I hear a loud grinding noise that most of the time will grind for a second then stop for a second and keep going on like that till I drive for a little or push the clutch it. Recently mya car started to make a quieter but continuous grind until I push the clucth it and this happens even when warm or I stop at a light and can hear it. Idk if it has anything to do with it but my car has a quick squicks on start up and has once quicked while I was stopped at a light starting to accelerate again.
My car also whines up until i get into 4th gear, 3rd being the worst. I can put it in natural in 3rd gear speeds and the noise will go away but when i go back into gear it whines again.
Lastly my car has gotten really hard to get into gears. It has its good and bad days but aleays has a problem with getting in gears. Here's how I can explain it. Say you're going into first, there's inistionaly two little clicks/bumb you feel I guess, and when you get past the first click/bumb you feel a second and thats how you know your cars in gear. Well mine doesn't want to get past the first bumb. (Idk to much about clutches and tranys so hopefuly you understood what i ment and im writing this on my phone so hope my mistakes arent to bad)
