H22a euro R main/rod bearing question
    Hi , here is some picture of my engine block can someone help me to figure out about what size to choose for main and rod bearings.
    I did my homework and here is some shot from the manual shop
    connecting rod bearing
    main bearing
    all of my connecting rod got the number 2 stamped on them
    you can see, they are real 11.1 compression piston
    Use a dial bore gauge and Caliper on your mains and crank and check your clearances.
      is not simple to just use the stamped number and letter ?
        Yes. You only need to check your clearances if you want to know whether or not to replace the old bearings. For new bearings, you can go by the stamped number and letter.
