Check Engine Light Code 15
    I posted before about my car stalling out. I jumped my connector and the CEL code was 15, which is Ignition Output Signal. Can anyone shed some light on what that is? How easy is it to fix, and how expensive would it be?
    Typically a code 15 means that you should start by testing your coil and ignitor or the wiring between the coil/ignitor and the ECU. Something is not right with the voltage signals the ECU is receiving from one one of them. Most of the time its the ignitor on its way out.
      Agreed
      Test your voltages.
        Originally posted by CaSpAr4Rm916 View Post
        Test your voltages.
        You are kidding right?
