I have a 1990 CB7 5spd f22a1 with a6 cam and full exhaust header back. I'm constantly back and forth about going all motor or turbo for my car. I have a few parts laying around: DSM turbo manifold, 550cc Chrysler injectors (srt4), starion stock front mount, volvo tdoh14 turbo with only 50k on it but the flange doesn't match to anything but volvo and a 16g with a frank 20g wheel that is in serious need of a rebuild and hot side.. I just want a fun car that I can daily drive and still be my family car. Not looking to break world records. Around 200hp and I'd be happy. Id like to keep my a/c if possible. So I guess im mainly looking for opinions on a route to take and suggestions to go along with it. Im not a newb to cars and ive built a boosted d16 ef hatch before. So feel free to leave comments etc. Below, thanks
Too boost or not too boost? That is the question.
You'll need a custom manifold to keep your AC. It can be done, but it won't be cheap (unless you're capable of building it yourself.)
You'll need to install forged pistons if you want the engine to last. Install a turbo on stock pistons, and you'll be lucky to get a few months out of it before you break a ring land.
If you've already boosted a Honda, I assume you're familiar with the ECU tuning requirements, and what is involved.
A DSM turbo can be had and for cheaper if you decide to boost it. 13g's are usually dirt cheap and 14b's are just a little more. If you're lucky a S16g can be found for cheap sometimes too. Just stay away from any 16g's that are fakes. They usually don't last. If you're only going for 200ish HP, I'd go with a 13g, or 14b. They spool quick. And you could just go with a stock DSM side mount also as one of those two turbo's with be fine with that.
The 14b was once THE turbo to use around here. Then, for a long time, we were convinced that it was too small, and produced too much heat. Then a member (toycar) came along and explained in very specific detail why the 14b is a perfect size for the F22A.
So I definitely agree with that suggestion if you're on a budget. Still go with forged internals, though.
Honestly, to do it right, it's going to cost you about the same to get 200whp N/A or turbo. Both will need internals. Both will need a tune. The cost of a good turbo setup will come close to the cost of headwork and a good camshaft (necessary for 200whp N/A, but not for turbo.)
The side mount is iffy, though. The CB7's bumper wasn't designed to flow air to an intercooler in the fender area, so it won't cool as well as it did on the intended vehicle. I'd stick with a front mount. The Starion front mount is a decent choice. I actually had one of those for a kit I built (but never installed... stuffed the car into a wall before I got around to it.)
If you change your mind and think turbo again, I believe Treadstone still makes a full kit for us. It's not the greatest stuff, but it's a nice, clean, easy kit full of brand new parts that's made to fit. Takes some of the guesswork out of it, and it will look better than a slapped-together kit. They run about $2000, though (give or take, depending on selected options.)
